Hi all I'm having a problem with my raven heat boiler t no hot water CH works fine just no hot water had a engineer look at it he said it was the DHW sensor so got him to replace the sensor that didn't work he said it was the PCB I replaced that no change , the three way valve had a little leak so i'v changed that as well
If i the bolers lit IE heating on and i turn the hot water on the boiler goes off
If the CH is off and i turn on the hot water tap the pump starts to run but the boiler dosen't start
little question on DHW sensor should there be a resistance across the pins or is it a open and closed switch
thanks Chas
thanks Chas
