just checking before i splash the cash..
got a ravenheat ls80 t, agreed to work on it for a nurse as no one locally will touch it.
ch spot on works fine. hw nothing happens when tap is opened, only way she has wot water is if micro switch on diverter is removed ( press switch in on micro switch when it is removed and hot water demand and boiler extinguishes)
what is the permanent solution??
simple answer i'm certain but as normally work soley on bbu and installs i'd appreciate some advice
