Any advice gratefully recieved:
Whenever I either turn on the DHW tap or CH the boiler will fire up and the fan will start but after around 5-10 secs the boiler will make an dreadfull clunking noise and will stop the ignition/flame
There does appear to be a small amount of water discharged from the outside valve.
If I turn the thermostat right down on the CH it will fire and stay fired until it reaches the requested temp - However if I keep turing the thermostat up it will cause the clunking noise and the boiler will cut out.
I have looked at the plate heat exchanger and DV and they both appear to fine (water flows nicely through exchanger) free movement in DV - no really sure how else to check DV ??
Can anyone suggest what else to check ??
Is there a way I can check the pump functionality ?
