hi my ravenheat boiler model rfs84et has no hot water boiler will not fire up when on hot water only ok on heating but still no hot water when tap is turned on could this be a diverter valve or micro switch problem any help welcome thanks.
microswitch ok freed off pin in diverter valve boilre now fires up but water only luke warm and rads warm up when hot water is on any suggestions would be welcome thanks bg
