Hello all,
I have a problem with a ravenheat combi boiler as the header states.
When it tries to fire the fan comes on and the pilot ignites so the firing sequence seems fine. The problem is that it does not come on fully all that happens is the pilot stays on nothing else. The central heating pump comes on i have tested the stats etc. Checked gas pressure and that is ok. It has a cvi modulating valve. The burner pressure is nil. Could the valve be faulty?????
