I have a Ravenheat RSF820/20 combi boiler fitted for the last 5 years. For the first 4, it has been faultless, but over the last year, there are one or two problems appearing.
First of all, the timer seems to alter itself, changing the on off times and days of it's own accord.
Secondly, when the unit is heating the radiators and you either call for dhw via the shower or the taps, it works fine, warming the water up nice and hot. However when the radiators are off, and dhw is called for, the water temprature doesn't heat up very much at all. I have also noticed that when this is happening, the radiators are heating up, even though they shouldn't be on. After reading through the manual, i understand that when the radiators are on and dhw is called for, the radiators should switch off while the taps call for water, not the other way around?
If anyone has any advice I would be very grateful.
thanks
thanks
