I have a ravenheat silver star (I know you all think they're crap, but it was all I could afford at the time and it's worked well for three years)
My problem is I noticed the radiators were hot all day and I assumed it was the timer - a friend with the same radiator has had to replace one. But I think not. Even in summer mode with no CH selected, the boiler fires for about 30 seconds, the shuts off for about 2 minutes, then fires up again for 30 seconds and so it goes on during this time the CH flow and return pipes are pretty hot. The only way to stop it is to switch the boiler off completely.
Also, I'm not sure if it's related but the DHW runs at the right temp for about 5 minutes, goes cold intermittently, then back up to normal temp again.
If it's a timer or PCB or anything electrical, I can replace it myself (I'm a sparky), also if it's anything on the wet side I can flush, and drain as needed. Gas - I've got a tame CORGI friend, but he doesn't do Ravenheats.
Any thoughts before I reach for the yellow pages ?
PS. There was a post on here a while back about ravenheats not sparking, firing but then shutting down. Check the live and neutral are not reversed on the mains supply. They're polarity sensitive
