I have a ravevenheat 85HE Combi .I have had problems trying to get HW to ignite and i have now removed external thermostat and put the loop wire in its place, changed clip on thermostat and wet HW stat changed 3 way diverter valve and switch.
With HW set to summer open tap and now it fires up and heats up (sometimes refires a few times)
If i set swich to winter and turn up built in temp control the boiler ignites and rads warm up when i turn down the built in temp switch the boiles turns off but there is still something running (low) sounds to me like a fan if i move switch to summer it does not make the noise (fan) Reset and put back to winter (temp switch at lowest) boiler semi ignites for a few seconds then goes off and leaves the constant noise (fan) any ideas????
I am awaiting a friends recomendation for a trustworthy enginner to have a look.
