I'm refitting a hand rail/bannister to the brick wall going up my stairs. It's fairly heavy and I've bought some new brackets but the screws seem a bit short (30mm) so I was going to buy some 60mm number 8 screws and use wall plugs. There will be 4 brackets, each with 3 screws. I was wondering does it matter what length the wall plugs are? The ones I have to fit number 8 screws are only about 30mm long, plus the depth of the brackets which are roughly 5mm, means I'll have 25mm of the screw beyond the end of the wall plugs. Does this matter as I can't seem to find any longer plugs that will be suitable for a number 8 (4mm diameter) screw? I've seen some people suggest putting in 2 plugs on top of each other. Thanks.
