Hi all. Thanks in advance for taking the time to help.
I have moved into a house with a wood-fired Rayburn in the kitchen, which I think is a Rayburn 212S although it does have the priority damper lever shown here: http://www.rayburn-web.co.uk/raytech/on355.htm
Anyhow, this Rayburn is connected up to the heating so is meant to heat the 5 radiators and towel rail upstairs. The problem we are finding so far is that we can't get the darned thing hot enough. I get it started ok with the spin wheel and chimney damper wide open, add some nice dry logs (gradually), then close the damper 2/3 of the way and turn the spinwheel in a bit, but the thing just idles along without ever getting really hot (circa 100 degrees max) and I've tried playing with the spinwheel and the damper, and even the chimney flue but can't seem to get the thing roaring away.
Because of this, we can't cook in it and the radiators just get a little bit of warm water at the bottom (I have bled them all).
Any thoughts what I am doing wrong?
Thanks in advance again!
Andy
Andy
