My lighting circuit is protected by a 6 amp RCBO. I have, amongst the normal house lights, a 60 watt pendant in the porch and 2x50 watt halogen downlights switched together in the kitchen. The problem: when I switch the porch light on at around 9 p.m. for the dog, the RCBO trips. I reset and try the halogens and the RCBO trips. No other lights cause the problem. So, I decide to sort the problem the next morning. Morning comes, try porch light, all OK, try halogens, OK. Repeat the following evening, RCBO trips. So it appears that the fault is only there in the evening. I have reproduced the evening lounge lights setup in the day and the problem is not there. Any bright ideas? (excuse the pun)
TIA
TIA
