D
DAJ
As some of you may already know, I have recently installed a new 16 way consumer unit containing 6 x 6a, 5 x 32a and 1 x 40a RCBO's. 6 x light circuits (1 x outside), 5 x socket rings (1 x outside) and a cooker/hob outlet. It replaces 2 old fuse boxes, 1 x 4 way and 1 x 2 way (plus new circuits).
Most of the new CU is feeding new circuits but there are 5; 2 old 5a lighting and 2 old 30a socket, 1 x cooker, that have been simply removed from the old fuses in the old box (CU) and put into the new CU. That is to say the cables removed from the fuse block and N bar in the old box and put into the new RCBO (L & N).
Everything seems OK and is working absolutely fine. HOWEVER – today I completed the transition and the very last RCBO installed trips immediately. The neutral is located OK in the bar and the earth ‘fly’ is inserted OK. The RCBO is for an existing 6a lighting circuit which has been working fine for over 15 years. I simply transferred the cables as described earlier. The RCBO trips as soon as it’s switched ‘on’, even with no load on the circuit.
As the lights have operated fine for all these years, would I be correct in saying that the cause is probably a borrowed neutral from elsewhere? If this is the case, how can it be traced and rectified?
PLEASE no criticism and quotes from BR and/or part P, just some advise if you can help – thanks!
