I have a Hager CE464J installed in my house to feed a number of AC split units+some other loads. Sometimes, when I am alone at home, non of the AC are turned on. However, when I wake up at morning, I see that the breaker has tripped.
In order to fine the issue, I decided to trip load CB connected through the RCCB to try to isolate the problem. I ended up tripping all the CBs, and still getting RCCB trip everyday, almost the same time! And once the RCCB trips, I can't reset it unless I wait for at least an hour.
Even worse. If I am running load ( 3 AC units) at night, I get a RCCB trip. But this time, I can reset it immediately. But after 5 minutes, the RCCB trips again. SO i reset the RCCB, but this time, it lasts for the entire night and only trips at sunrise!! which then, the RCCB need to wait for an hour to be resat.
I think I am facing two issues not one. But I am not aware of the proper troubleshooting process. I am thinking of installing a 0.3A RCCB instead of the 0.1A I have now. Other than that, I have no solution.
Sorry for the lengthy post. I appreciate all the help and comments.
regards,
regards,
