- Joined
- 15 Jan 2022
- Messages
- 1
- Reaction score
- 0
- Country
I recently installed a Homezone LED PIR light on my garage which I plug in to the garage socket.
All worked well when switched on the lights lit up and after some minutes went out, I checked the PIR and it turned the lights on. However after ten minutes the House RCD tripped. I already have the same light fixture over the front door so I thought the new fitting must be faulty, I went back to Cost..and swapped for a new one. Went home fitted it and the same result. I read somwher that these units have some earth leakage and I guess the addition of a second unit (same as the front door one has taken the RCD to its limit, but why the delay? is that built into the RCD?
On reflection I decided to fit an older spare chines one I had kicking around in the garage, the tail was very short so I opened up the unit to find that the earth wire inside was floating around in the breeze with no visible connection point on the metal casing. surely that cannot be legal? In any case it wouldnt trip the RCD I guess.
Is there a solution that will allow me to use the new unit?
Sorry its a long post but I have searched Tinterweb with no joy.
Thanks in advance.
Thanks in advance.
