I've just had a bathroom refit. electric shower was taken out and the cable wired into a dead end junction box and left under the floor. the seperate fuse switch for this has also been switched off.
the switch for the extractor fan has also been wired into a dead end box.
I now have a shower running from the combi boiler and no new electircs in the bathroom.
prior to this I have had not problems, but since then I have had periodic fusing on the ring main, so far 3 times in the last 4 weeks(lights still work).
the fuse box will not turn on straight away. after about 10mins it lets me switch back on.
nothing seems to prompt it to happen, I can boil kettles turn on toasters and run as many appliances as I like and I cannot make it happen. it just does for no apparent reason
there is not specific time or pattern to it.
does anyone have any ideas? do RCD fuse boxes wear out? could it be that?
could an electician trace a fault like this easily?
