I have the following electric box:
Photo 13-02-2012 08 38 37 by Ross Dargan, on Flickr
and the trip on the right hand side (the main switch) keeps tripping - sometimes once a month, sometimes once a day - it's very random, here are some of the most recent times (I have a UPS which is why the times are so accurate).
08/01/2012 07:15:51
19/01/2012 05:40:12
24/01/2012 01:22:52
31/01/2012 19:11:05
01/02/2012 04:06:39
05/02/2012 11:25:41
07/02/2012 00:23:14
As you can see there isn't really a pattern - and since then it's only tripped once more.
I have had an electrician in who has checked all the wiring and confirmed that it's fine, so he things it's probably an appliance now.
His only remaining advice is to unplug everything and try and figure out whats causing it - but given how it can go months without tripping this approach could take years.
I was wondering if I could instead use several off the shelf RCD socket (the type you would use to protect a lawn mower) to try and figure out the appliance causing the issue - I would attach every appliance that stays on all the time to an RCD and when one trips hopefully I will have identified the issue.
My question is will the above work, or will the RCD on the box be more sensitive? Is it more likely that the RCD on the box is broken - should I get that replaced first?
Any other suggestions would be really appreciated as this is starting to get expensive!
Ta
Ross
08/01/2012 07:15:51
19/01/2012 05:40:12
24/01/2012 01:22:52
31/01/2012 19:11:05
01/02/2012 04:06:39
05/02/2012 11:25:41
07/02/2012 00:23:14
Ta
Ross
