I have a problem with an MK Sentry split load board that I'd like to share...
When I connect the earth from the supply head into the earth terminal from which I have fed the consumer unit with, the RCD trips.
I have checked every socket on the RCD side of the board for any faults - there are none.
If the earth is disconnected from the board then the RCD operates - no problem, but once the board earth is linked to the supply head earth it trips even when there are no circuits in operation i.e. all MCBS even those on the main incoming are switched to the off position.
The board is configured in such a way so that the tails from the meter come into the board and enter the main switch at the top.
On the left side (bottom) a tail then feeds the neutral bar.
The right side (bottom) is attached to the busbar and has MCBS for lighting circuits, boiler and smokes.
There is a link from the neutral bar (main side) to the top left terminal of the RCD then a link left bottom to the split neutral bar.
There are no obvious connections in the board (like neutrals on the wrong side of the RCD, MAIN SWITCH so I am stumped....
All suggestions appreciated
Lee.
Lee.
