Hi, I have purchased a Blagdon Powersafe Armoured Garden power supply kit. It states that its complies fully with IEE wiring regulations and can be fitted by a competent person. I am basically running this to a 5 way IP66 rated switch box for garden lights, pond pump, waterfall and decking lights. The instructions say that to comply with regulations the cable must be plugged into an RCD socket. My question is this, as my consumer fusebox is a dual RCD type can i run twin and earth (2.5mm) to a standard spur and then plug the cable in here direct?
Actually a second question while I am here is once this 5 way switch box is fitted, can i run an armoured cable from the switch box (gland) to the first 240v/42w Lamp and then daisy with standard twin and earth clipped to underside of decking?
any thoughts would be welcome.
