Hi guys,
I wonder if any of you could give me a little advice, I've installed an IP66 rated socket in an outhouse adjoining my house. This is fed from a Safetysure RCD spur, wired as a spur from a double socket next to it.
When I turned my electric back on at the consumer unit the external socket worked, I tested this with a socket tester, all LEDs lit to show it was wired correctly, this issues arise when I press the 'test' button on the RCD, this trips not only itself but also the RCD on the consumer unit. As a test I wired this as a spur to another socket on the ring main but got exactly the same issue. Am I overlooking something or is it more likely I have issues with the electrics in my home?
Many thanks in advance.
Mark
Mark
