I purchased an RCD spur recently, this one
http://www.toolstation.com/shop/Ele...+Metalclad+1+Gang+13A+30mA/d190/sd2470/p11214
I have an outside socket that is used for the lawnmower/strimmer but it has always just been part of the ring main and my consumer unit is not rcd protected so figured it was about time I got some protection for the missus when she cuts the grass.
Anyway I fitted it today (I pulled the 2 ring main cables back through into the shed, fitted them into the spur, then ran a new 2.5mm t&e back through to the outdoor socket.
When I switched te electric back on I pressed the reset button on the spur and the indicator went red as stated. I then pressed the reset button to test it and it tripped the main switch on the consumer unit, killing the electric for the whole house.
Now I guess this is sort of doing it's job by killing the electric but it's not quite what I had expected to happen.
Is this likely a faulty spur, me doing something wrong or just one of them things. The socket works fine btw but I want to make sure it's doing it's job before I proceed, otherwise I will just take it out and carry on as before.
Any help would be appreciated
