Thats what most engineering inspection companies use (usually digital version) so sounds OK. Is it calibrated????
If you're going to do a lot of other tests then I'd get one of the 5 in one meters from Robin which will do earth loop impedance, PSC, insulation resistance, continuity and RCD testing
If you need any spare parts, let me know......reason being, the engineers (so called) like to put them across 3 phase.......Now using the Avo/Meggers LCB series which can take 3 phase.....
Thanks,
I have looked at the options, and some of them are very expensive. I thought that to calibrate a unet will cost about £30 and if it is an used (16th edition) tester, it might be ok.
Albert
