- Joined
- 27 Jan 2008
- Messages
- 25,038
- Reaction score
- 2,903
- Location
- Llanfair Caereinion, Nr Welshpool
- Country
I have had one supply altered to a FCU and two double sockets fitted all from the same supply which is an UPS, not sure on the reasons why, but instead of a RCBO as I would have expected I have two type A RCD sockets and a FCU, the latter is the reason to query.
I did not realise until after they had left, it was a standard switched FCU feeding the boiler, not a RCD FCU, if there is no RCD before this, then that means the thermostats, relays, pumps, motorised valves, and boiler are not RCD protected. It may well be there is a RCD in the inverter that feeds the sockets and FCU, but the question is will that become apparent once the documents arrive?
I don't want some unsuspected guy servicing my oil boiler to come to grief due to missing RCD, I had expected the boiler to have had a plug and socket fitted, allowing me to revert back to standard socket should anything go wrong with the inverter, as I can with the freezers, when I saw the FCU and that it was not a double socket so I could also plug in the back kitchen freezer, I thought about it, and thought well likely I will move the fridge/freezer anyway, so I will just spur off the FCU once I know where the freezer is going, OK I know notifiable but cost of getting a scheme member electrician to do the job, will not be that much, so hardly worth worrying about.
But the fact that there is no longer a single point of isolation for whole house, means there is a possibility that the wrong FCU could be switched off by some one servicing the boiler, so there is a real danger that a plumber, clearly an electrician will always prove dead, but a plumber could turn off the wrong FCU, if he did would I as the home owner be libel?
But could be worrying about something which does not exist, there may be a RCD I am unaware of, so with the old forms I use to use there was not really a provision to enter multi RCD disconnection times for one circuit, has this changed?
