Hi everyone,
i have a question reegarding rcd tripping.
i know that this has been discussed before but i cannot seem to find the threads so i have to start this thread.
i work on street lighting and infrequently come across residents who claim that their house rcds trip when the street light switches on.
i tell them the same thing every time
check to see if the fridge is switching on at that time, or the immersion or an outside light or a boiler etc.
today i was called to a house and the lady said that she had called a qualified electrician to check her installation because of nuisance tripping.
they carried out a thourough examination but found nothing untoward and put it down to an intermittent fault.
however she noticed that the trip operated every night at the same time as the street light came on.
i explained the usuall checks for her to do
coincidence i said!
and to prove it i would switch the street light outside her property on at that moment
to my unbelief the 30ma rcd operated
as it did for several times in a row afterwards.
the rcd resets ok when the light is on it just trips on start up.
the street light is fed from an overhead 4-wire network, off the brown phase,
and the house is fed from the grey phase
i have left the light on burn to prove if that particular light causes the rcd to trip or if other lights cause the rcd to trip.
the house supply is a single phase overhead supply feeding two other properties looping from the first house to the ladys and then to the next house.
any ideas as to what the cause may be!
gratefull for any ideas folks
coincidence i said!
