Hi
I have had the RCD trip out on about 3 occasions over the last month or so at varying times. When I go to reset it, it does not stay on until I switch off the downstairs socket switch for the kitchen area and then everything works fine. If I try to switch the downstairs sockets on after a couple of minutes it will trip straight away but if I leave it for about 20 minutes and switch it on it then does not trip out.
I have unplugged every appliance apart from the built in fridge and freezer and when I try to turn it back on straight away it always seems to take 20 minutes before it will stay on, is their an explanation of why this takes so long to come back on when hardly anything is connected.
I do have a small old table top fridge that is quite old that maybe the likely culprit as most other appliances are fairly new.
I have a socket tester with the 3 lights that I can test all the socket outlets with and also a digital meter. Is there a way I can do a resistance test on each appliance from the plug. If so what do I put the setting on the meter to and where would the test leads connect onto live and neutral or live and earth.
Regards
Mark
Regards
Mark
