RCD tripping on fluorescent light
1 Sep 2004
Hi
I have a problem with the main RCD (before CU) tripping due to a fault in only one circuit - 2 x fluorescent light circuit. All other circuits are ok.
RCD trips when lights are switched off. I thought I had located the fault within the ceiling rose for one of the lights and made good all connections which solved the problem for a while (1 day), but since then it has started again.
Any ideas as to where the problem may be?
Are fluorescent lights prone to this, when there is maybe a problem within the light fitting?
Any advice would be much appreciated, thanks.
How about isolating the suspect fitting and see if tripping continues?
If not, replace fitting.
Thanks for that. 2 lights, so I will isolate each in turn and take it from there. If it stays with one of the lights it will be a new fitting as you said.
If there's still a problem with either one I will check connections at CU, thanks again.
