Hi, I have a real problem which I have posed on here some time ago and was given lots of good advice. However I still have same prob and have more info so am asking for any advice again.
I will try to make this as short as possible!
I had new electrics installed nearly a year ago, we have a consumer unit with rcd. All tests carried out at time of install were fine.
When we moved into property we had a new washing machine installed which tripped the rcd, had that machine swapped out and the same thing happened.
We then had an engineer out and he tested the machine said it was fine.
The next thing to trip the rcd was the computer (I understand this is common) then the printer, then the LCD tv.
All of these things have been tripping the rcd since first bringing them into the property, however we can use each of them with no problem, infact we can use all at the same time with no problem but out of the blue it will trip, or when you plug in and switch on or off the socket it sometimes trips.
Just a couple of weeks ago our main tv in the living room started to trip the rcd and only last night the tumble dryer did it both have not done it before.
Now we have had our electrician back and he is baffled, he has done an R1R2 test, mega tested all downstairs sockets, he has put 500v through the system and found no faults, he has changed the rcd and the same happens.
Sorry if I'm using the wrong words but not up on electrician jargon!
He said the machine he used is showing 2.99 reading and that is what it should be.
So of course he thinks it is the appliances, unfortunately he does not have a PAT tester so we took our printer to a friends house last night, he has a 2 year old consumer unit with an rcd at 30 m/a.
We spent some time trying to make his rcd trip but it just wouldn't, as soon as we got the printer back home we took out every socket in the house and plugged the printer in, it tripped!
Took the printer out and plugged the lcd tv in same again, so the final thing we did was take the tv out so no plugs in and switched off all rcd switches, with the main rcd switch on we started to switch on the switches 1 to 5, a couple of times nothing but then it tripped on number 2 which is downstairs sockets, then number 4 which is kitchen sockets and then number 3 upstairs sockets, remember nothing is plugged in!
Sorry this is so long but I thought you would need all of the info I have, we are now looking at having to pay someone to come out and do a PAT test but I'm worried about where we go if the tests are fine!
