Afternoon all
Please can someone offer an explanation to the following ,
on my home CU I have the cooker, up and downstairs rings and the garage protected by the RCD side of the CU, last night I switched off the bedroom light in the small bedroom and the RCD tripped out , I went downstairs and reset it and again turned of the light in the small bedroom and again it took out the RCD
I can recreate this every time with the switch in the small bedroom
It occurs when turning thr light off , however when I first noticed this occur I pressed the switch to turn the light off and stopped and held the switch in ( my little 1 cried out as I was about to turn the light off)
if I flick the switch on/off as normal its fine but if I hold the switch in between on/off it takes out the RCD, im just after a an explanation pls as to why ?
The lightingisnt on the TCD side so this does puzzle me a bit that its the RCD going and not the breaker...
Cheers
Cheers
