- Joined
- 16 Jan 2011
- Messages
- 4
- Reaction score
- 0
- Country
Yesterday the electrics in half the house went off - and basically the VR80 RCD which protects 5 circuits on the left side of my CU won't reset - even with all the associated MCB's switch off. I have another VR63 RCD on the right hand side protecting a different set of MCB's that is fine.
When I try to reset it I can see a quick spark from the area of the top right hand screw of the RCD. From reading through this forum I see that a neutral earth fault could still trip the RCD even with the MCB's in the off position - is that correct? And to see which one is likely causing the problem I should disconnect the neutral's in turn ?
Would that be the neutral's on the bar in the top left of this picture (from another post) //www.diynot.com/forums/viewtopic.php?p=1147347
My CU looks exactly the same.
Also I have seen people suggest to make sure all cables / screws are tight.
My main question is that if I put down (off) the master switch in the CU then as long as I don't go anywhere near the top two screws and cables on the master switch on the very left hand side of the same picture which is where I can see mine comes into the box as well will I be safe tightening up things and disconnecting neutrals one by one ?
Andrew
Andrew
