- Joined
- 20 Nov 2003
- Messages
- 61
- Reaction score
- 0
- Country
I assumed, when I first started learning about British electrical work, that a UK Residual Current Device and an American Ground Fault Current Interrupter were virtually identical. However, in the recent "kitchen ring" post in the UK electric forum, I found the following two statements:
BR said:This 80A RCD (question 1 answered!) means it can 'monitor' a max of 80A of current at any one time. This is probably quite adequate but remember that an RCD does not protect against over current so a 32A MCB should be installed in conjunction with this. This RCD can be used along with an additional MCB to protect a new Ring.
This casts doubt on my assumption. A GFCI provides both overcurrent protection AND ground fault protection in one package. Am I to understand that an RCD provides ground fault protection only, and that a circuit breaker must be installed in series with it?ban-all-sheds said:knowledge on the difference between RCDs and MCBs, and where in the hierarchy of protection they sit, and what kind of protection they provide....
