I've been having problems with the RCD tripping a couple of times over the last week or so, but each time I reset it it was ok for a couple of days. Now whenever i try to switch it back on, it just springs back.
There are 4 circuits on the RCD - 2 socket circuits, oven and water heater. With either of the socket circuit MCBs switched on, the RCD springs back straight away. With just the oven MCB on, it works fine until I switch the oven heater on and draw any current, then it trips straight away. Also with all the MCBs switched off, the RCD will stay on for maybe 10 minutes but will then trip - even though there should be no current flow(?) Could this be a fault somewhere within the CU itself..... Any ideas what to look for/check?
cheers, Steve
cheers, Steve
