I am looking for some advice please.
We have a vented hot water system with a salamander water pump on the hot water system. It works fine when the taps are used but it doesn't come on automatically when you use the shower (which is connected to the pumped hot water system and mains cold) - presumably the pressure drop through the thermostatic shower valve is too much to get a flow sufficient to turn on the shower pump?
We have managed with this until now by blipping the hot water tap and this fires the pump into life and therefore the shower. However, at the time of the initial problem we bought a RCM1 negative head system on our plumber's advice just didn't fit it.
A plumber is coming in tomorrow to do various bits of work and I asked him to take a look at it but he suggested it wouldn't work but didn't understand what the RCM1 does.
Is he right or do you think the RCM1 is correct for this situation? Are there alternative fixes to this? The plumber who fitted the pump has already maximised the flow of hot to the pump (larger pipework, increased height of the tank etc.)
Thanks in advance,
Paul
Thanks in advance,
Paul
