I have a new cooker that is rated 9.8KW – 10.7KW. The distance from the consumer unit to the cooker is about 13 meters and the cable is 6mm. I have just had this cable and cooker installed by a qualified electrician. I am a bit worried that the cable is not going to be future proof and only just within the rated spec for this cooker.
My question is, do I ask for the cable to reinstall with a 10mm cable or do you think it is ok to use the fitted 6mm cable with this cooker?
I was told it would be fine.
