Can anyone advise an acceptable/ best way to joint the gap between Sandtoft half round concrete ridge tiles on a garage roof. The gap between the tiles is only about 2mm (unless one is cut down). The roof rafters (welded steel) spacings are excessive which I would imagine means the roof will flex a lot, especially while the ridge is being refitted.
A friend suggested using silicon sealant but I’m not at all comfortable with this unless it’s classed as an acceptable method that would have good longevity
Any help would be much appreciated, many thanks.
