RE: BOILER SWITCH 900 PROBLEM
17 Feb 2014
Hi Everyone,
I recently came across your great forum by accident and hence I have just joined as I'm after some HELP Please !!!
I currently have a Switchmaster 900 programmer fitted to my central heating system, controlling heating and hot water.
MY PROBLEM - The timer has ceased to function !!!
Can someone please recommend what would be either the best replacement for a Switchmaster 900 CentralHeatingController or if this is a fixable problem as my switch has never broken down before and if so what is the fix ?
If unfixable, then I would prefer an electro-mechanical version if possible otherwise a digital compatible, if no alternative is available, and also one that requires the least re-wiring.
Question #1 Is the problem Fixable ? What is the Fix ?
Question #2 How easy a task will it be with the different wiring system to fit ?
question #3 If unfixable - Which replacement item is best Mechanical or Digital and please advise model number and which type is best ?
Question #4 Where can I find one and how much would it cost as mine is old and hence may not make them anymore ?
Question #5 Where can I find a link or a copy of the original manual for the switchmaster 900 to get the original wiring diagram from....
Any help would be very much appreciated.
Thanks In advance
Wolverine747 :(
Thanks for the info 45yearsagasman – However, I have no idea which one to best choose.
I would prefer to replace the current version I have with a similar version if possible as I’m rather fond of the electro mechanical version and especially since I have had the Boiler for the last 10 years and this is the first time that I have had anything go wrong with it.
Can anyone please suggest or recommend where best to get hold of a replacement Switchmaster 900 please and how much it would cost ?
Thanks.
Wolverine747
Dear All,
Can someone please advise me which Boiler Programmer would be best suited to purchase and is compatible and is also easy to fit and most reliable as a replacement for my faulty Switchmaster 900 from the list below as uinsure which one to choose:-
1. Danfoss 7 Day Digital Timer – FP715 si
2. Horstmann – Centaur Plus C21
3. Siemens RWB29
4. Horstmann 425 Tiara Programmer
Also how much I can expect to pay for one of these items.
Thanks.
Wolverine747 :(
