- Joined
- 27 Apr 2008
- Messages
- 9,670
- Reaction score
- 953
- Country
Hello all, this seems the right place for it here seeing as its a wood covering
Its a dressing table from Jan 1960 that I got off of Freecycle.
It did have a Beech veneer coating on it that was pretty well stained & mucky etc.
I have started sanding it down & have removed the stained beech veneer that was on it & now have a lovely wood finish (plywood lol) that I can treat as I wish.
What I am thinking of doing is staining it light oak & perhaps putting on a waxed finish.
I have never used a waxed finish before, usually plumping for varnish but I think that something that needs lots of fine rubbing (lol) might be a bit better & give a better look.
I have heard of french polish & seen stain/polish at the sheds but am keen to find out what would be the best finish & how to go about it?
(I also have to bear in mind the costs).
Er indoors just wants it stained & varnished as cheaply as poss, but I'm a bit more of a fusspot & want to do it better.
Will a waxed finish make it as durable as varnish if its having lots of tins & tubs of make up & other such facial gunk on it?
What would you recommend I apply & in what order & how etc?
Thank you.
Matty
Here it is when I started.
Here you can see the veneer top I wanted rid of:
Here you can see what it looks like once I have done most of the sanding & wiped it down.
WE may forgo the stain & just use clear wax- recommendations anyone?
Thank you.
Matty
The original veneer top
- mattylad
- 1
Just a shot to show the original veneer top/glossy finish that is not in too good condition.
Just washed with white spirit.
- mattylad
- 1
Just washed it down with white spirit to remove the sanding dust.
