I was suggesting this method was used with felt not Tyvek.But that wouldn't work so well for a breather membrane.
Thats the first time you've mentioned you have a room in the roof, I have no idea how the regs are applied in Ireland but over here you'd be likely to need to sling a layer of continuous insulation beneath the line of the rafters in addition to insulation between the rafters to comply. You could look at Triso if its allowed.Want to use a breather because the rafters are only 100mm and about 50% of the ceiling is against the rafters - don't have space to be leaving a 50mm ventilation gap - i intend to fill that 100mm with insulation.
