Afternoon all,
I'd REALLY appreciate some advice. I've just had someone in to refit my bathroom, in a Victorian terrace so the bathroom floor isn't level. Instead of using the shower tray riser kit he told me to buy he has put the shower tray onto a cement base and the finish is awful (as in the cement is exposed, has gaps in it) and the shower tray is not quite level as water pools behind the plug (it's an offset quadrant). I asked him to either correct the job or take money off the quote, so he filled in a couple of gaps and then put some white stuff on it and he thinks that's acceptable. It still looks awful. He won't do anything more to it so has taken some money off but I'm not sure it's enough to fix the issue properly. It's my first experience of having anything big done and feel totally let down.
So, my question is should I try and find someone to lift the shower tray (which will require the lower tiles being removed from the wall as well) to remove the cement base and refit with a riser kit, which will sort the shower levelling issue and trim, or just accept the pool of water and find someone to make good the trim, which I've read and head using a piece of upvc can do the job? Any ideas on how much it might cost to lift and re-fit the shower tray please?
Thanks for any advice.
Charlotte
Charlotte
