I have read lots of posts on DIYnot forum to try and understand our problem with a cold ground floor extension and many have been really useful, though there are often different opinions, which gets a bit confusing for someone who is completely new to the subject of flat roof insulation! Basically, our one-story, ground floor extension, which was built by the previous owners of our house, is so cold in autumn, spring and especially winter as to be virtually unusable, unless you really like having frostbitten fingers! In the course of doing up the shower room, study bedroom and kitchen which it houses, we want to strip it right back and retro-improve the insulation as best we can. I am happy to get on and do jobs like insulating and plasterboarding myself – not a problem – but I want to make sure that I do the insulating correctly, as I know that getting it wrong can lead to problems with condensation, damp, etc. So, if anyone here is able to help, I could really do with telling our own situation and asking for your advice on whether I’ve got the right way forward planned.
If I understand correctly, a warm flat roof is almost always preferable to a cold flat roof, and that in new builds cold roofs are pretty much unknown these days. However, our building already exists, and it has a badly/partially insulated cold flat roof, with soffit ventilation strips running down both sides of the roof to ensure a through-flow of ventilation. It loses so much heat, though, so my plan is to take down the existing plasterboard and remove whatever roll-out insulation there is above it, and replace it with Celotex (of undecided width – what would be best?) jammed up between the joists, taking care to leave a gap between the top of the insulation boards and the underside of the roof deck (though I’m not sure what depth of gap) but no gaps around the insulation boards, and then to re-plasterboard, ensuring that the plasterboards are tight up against the insulation, with foil-backed plasterboard (with the foil acting as the vapour barrier – right?). In addition, we also plan to take out the existing downlighters and replace with pendant lights. Does all this sound about right?
I’m sure that a better course of action would be to get the whole 5m x 5m roof redone so that it can be changed to a warm-roof setup but, to be honest, we have such a lot to do on our house that we need to compromise between the course of action we take and the cost. So, do you think what we propose would work, and do a good job at keeping the extension a lot warmer, or is getting someone in to fit a warm roof really the only sensible way to go? I am especially concerned to get this right because the extension houses a shower room and a kitchen – both major sources of water vapour.
Thanks in advance for any help or advice anyone can give me.
