Hello, I’m currently stripping back to stone my living room in an 1820s cottage. The cottage is of solid stone construction.
I have removed the floor coverings (modern laminate) and discovered wet or damp concrete screed. I’ve removed the screens to reveal a second screed patially covered in bitumin paint.
On removing the 2nd screed I’ve got back to the original York stone floor which I’m hoping I can clean in keep. However it’s very cold under foot.
I’m considering lifting it up after carefully mapping it out, digging down and installing some insulation in the form of a floating floor. Sand blinding, dpm, pri boards, visqueen, concrete slab. Then re laying the York stone.
I’ve read contradictory information that this is a good thing to do. And also bad. The reason for it being bad is that the dpm prevents the floor breathing as it would have originally done. I’m not sure omitting the dpm would make much difference as the pri and polythene below the slab would also act in the same way and push the moisture sideways anyway.
I appreciate the existing concrete screed and bitumin would have caused the same issue but I’d prefer to do this right rather can cause more issues.
Any advice greatly received.
