When we first moved into our house last year, we noticed what we thought was an area of damp - carpet and lower wall was mouldy - in our bedroom behind where the previous owners had their wardrobes. At the time we couldn't see any actual water, and no obvious reason for it to be getting wet, so we assumed it was just damp that you sometimes see behind wardrobes due to lack of air circulation. So we re-decorated our bedroom, painted, new carpet, checked the walls, used waterseal on the outside wall etc. Put our wardrobes up, in the same location, but not pushed right up against the wall + they have legs, so allow more air to circulate.
We assumed this would be the end of the problem. Until last week, when we pulled the wardrobes forward again, and found the carpet was once again damp, with mould on it. However this time we could see water under the skirtingboard. Then it clicked, on the other side of the bedroom wall, is our en suite shower! I checked all the seals, and it all appeared to be OK. However at the weekend I decided to remove the shower tray, to investigate. After removing the shower enclosure, we then lifted the shower tray out, which caused the bottom row of tiles to pop off, and we saw the real problem! Water appears to have been seeping/leaking through the tile grout. We ended up taking all the tiles off, which was pretty easy, most just feel off! And we found what is shown in the below pic!
View media item 77299Water has penetrated the entire lower half of the shower unit, through the plaster, into the plasterboard, into the wooden stud frame, and under the skirting board, into our bedroom carpet!
Looking at everying, I would say the previous owners didn't user bathroom/waterproof grout, which allowed the water to seep through, and run behind the tiles - you can see water run marks where the tile edges would have been. Plus the plaster doesn't appear to have been sealed after it was skimmed/before tiling, and they don't appear to have used any special moisture resistant plasterboard!
So, down to resolving this mess! I need to cut out the plasterboard, and replace with a moisture resistant one. Which is the best to use? Wickes have 3 types, Vapour Panel, Moisture Panel T Edge or Aquapanel. After reading the catalog, I thought the AquaPanel, but the website calls it 'Aquapanel Floor Tile Underlay' (the catalog doesn't mention floor tile underlay) so I'm assuming it's just for floors, not walls? So Vapour or Moisture panel?
I'll also nee dto cut out the bottom piece of stud timber frame, which has rotted to the point that it's like a sponge. I should be able to chisel/knock it out, and slide in another block, before re-attaching the new plasterboard.
Once the new plasterboard is up, I'll need it skimmed. Is it easy to do this myself, or should I get a proper plasterer in? I have done normal walls in the past, but not shower/bathrooms. What's the cost likely to be? What's best to use to seal the plaster, before tiling? Proper Plasterboard Sealer, or a watered down PVA glue mix? I guess the plasterer would also do this, if we got one in.
The tiling is pretty standard, using waterproof tile adhesive & grout. And then seal the shower tray & frame in with a bathroom anti-mould sealant
Any help or advise would be appreciated!
