Re-Pointing now, ok or not?
28 Jun 2005
Surrey
Hi I need to repair some pointing on my house mainly at the damp proof layer and on a base for a shed that is bricked in the back garden, is now an ok time to do this?
I live in Surrey and looking at the weather forecast its about 8 deg C at night and 15 deg C during the day, although it was a little frosty last night.
Can I do it now without getting involved with special additives etc?
Also how far would you rake anything out to insure the new stuff is more than just a thin layer etc, I assume you need a thickness to it rather than just trying to make a skin in some places which seems wrong to me but please put me straight on this?
Any advice appreciated.
1. Yes, now is ok. No special additives req.
2. Rake out to 18-25mm, use an angle grinder if possible.
3. Practice pointing in an obscure area. If you feel confident enough, do your perps first, and then your beds. Dont strike-off until it's begun to set. Constantly clean your tools.
Cheers tim00, need to ask a bit more, around my shed the base is about 500mm bigger than the shed so that there are bricks to walk on covering the 500mm bit and then facing bricks 4 or 5 stacks high at the edge. I have seen people use a dry mix before with no water involved and brush the mixture into the gaps, is this an ok method to use as it seems a much easier method for pointing the walk on bit?
Hope I made sense.
Also on the house could it be a lime mortar and if so do I need to then use lime mortar to repoint, its a 1930's house?
How can I tell if it is a lime mortar?
Yes, your dry mix of 3 or 4 grit sand, and 1 cement can be brushed and packed in (some mix 6:1 ) to the walkway, and struck off. It will pick up ambient moisture and set without, potentially, messy watering.
1930's house should be a s&c mortar. A lime mortar is more easily crumbled.
