I'm trying to move the soil pipe position closer to the wall as it is currently 36cm to centre of pipe opening. I've managed to jackhammer a decent hole through the slab around the pipe now here's where I'd really appreciate some help.
The existing pipe is a 100mm diameter asbestos/cement type, this will need to be cut to lower it, then which connectors should I use?
I'll attach some photos to be clearer:
