Re-pressure glow worm combi boiler 30cxi
3 Jul 2024
Hi all, I have an old glow worm boiler 30 cxi that I need to re pressure after bleeding some rads. I looked on line and it said to turn the blue knob anti clock wise to fill and re tighten after when required bar pressure is reached. When I turn anti clock I can hear water, and it is dripping water from the other side of the boiler, but the digital display bar pressure is not going up at all, Can any one help please.
Show us pictures of the pipes and valves that enter below the boiler
I used to have a 30ci glow worm boiler, and sure I had this once (long time ago!), it could be the expansion vessel is low on pressure, when you are adding more water, its coming out of the the PRV (pressure release valve).
Others more qualified my offer their thoughts, post a pic of where it's leaking from.
When it was working did it use to lose pressure when it was off i.e. overnight?
