re,roof
10 Dec 2008
Cornwall
Hi All
Some advice please, i am going to reroof, has anyone used MonoPerm 500 breathable felt,this was reccomended has anyone encountered problems!
Secondley, insulation if i use KingSpan 100mm over the rafters i then counter batten then felt and batten also useing eves trays do the eves trays go under the insulation or on top and then the felt , or is it better to use foil insulation, if so can anyone reccomend one.
Finnaly, with insulation and the battoning do i have to raise the size of the facia board to accomodate the eves trays ie it sits on top of the facia?,does any one know of a good roofing supplier in cornwall.
Bill
eaves trays deal with the water run-off problems created by the fascia - eaves angle and also counter the problems of weathering and u.v. degradation. so it sits or is fixed directly beneath the roofing felt/membrane.
the fascia board covers everything from the soffit board up to the underside of the tiles and everything in between. ;)
Hi Noseall
Thanks for the reply i am still unsure about the eves trays, as in do they sit on top of the facia
thanks Bill
Thanks Noseall
Dont want to be a pain, but is Kingspan Or Foil the better insulation as i would need to replace the facia with king span.
Bill
the jury is still out on the foil stuff - some use it some don't. i'm not even sure whether it is B.B.A. licensed yet either.
i would always plump for kingspan/celotex.
why 'warm deck' anyhow?
Hi noseall
Thanks for that, sorry for delay in replying have been away,
what do you mean by warmdeck!
warm deck means the insulation is fitted above the rafters, effectively doing away with a cold side, hence no venting necessary.
otherwise you can fit the insulation between and under the rafters. this means having to leave an air gap on the cold side for ventilation.
