Sort of a plumbing question...
I'm fitting a new bathroom, and for various reasons the new bath is oriented 180 degrees from the old one. So the bath trap and waste pipe need to run along under the length of the bath to meet up with the existing waste pipework.
The bath feet kit consists of two extruded steel bars, which go across the width of the bath, screwed into the baseboard, and have the legs attached outboard. Problem is, the one nearest the plug hole prevents the fitting of the bath trap as it would foul.
I can't reroute the waste pipe under the floor board because it would interfere with existing copper plumbing which I can't re-route.
The only solution I can think of is to cut the bar into two so the waste pipe runs between the two parts, then make sure that the actual feet are directly under the bath baseboard, rather than outboard of this (which would result in the screws being pulled out and a small tsunami when the bath is filled).
Can anyone offer an opinion on whether this is safe/acceptable, or supply any other ideas?
Jim
Jim
