I have a SMEG DWF614SS dishwasher and it has developed a fault.
Every time the drain pump runs the dishwasher stops its cycle. On some programs this occurs 4 times throughout a program so its a bit of a pain.
However if you press and hold the 'play' button the drain pump will pump and empty happily and at a good flow rate. Once it has finished emptying then it happily moves on to the next part of the cycle and you can let go of the button.
If you don't press the button continually during this part of the cycle the dishwasher audibly starts to pump via the drain pump but immediately cuts out and stop the cycle.
I have stripped the pump out and tested it and it seems fine. Whilst inside I checked all other pumps, switches meters etc and all seem fine also.
Is this possibly a controller board failure or is the pump not quite as healthy as it seems when tested in isolation?
Mike
Mike
