M
macgrl
Sorry as this is a repost of a thread I mistakenly started in the plastering section.
It should really have gone it here so sorry for the double post
Hello all,
I am re-doing my bathroom and have taken off all the tiles, pretty much 2/3 rds of the room was tiled and will be retiled in the same place. When taking off the tiles some of the plaster underneath came off too so there are patches of bare brick, thin plaster layers and other patches of what seems to be plaster in good condition and not loose. I am planning on re tiling and so the replaster job doesn't need to be perfect but I want to it to be sound.
I am planning on basically filing in the gaps so that the replastered wall is all level and also level with part of the wall above that had no tiles removed and hence that plaster is perfect.
My questions are
i) Do I need to remove the good plaster patches so that I am down to the bare brick all over?
ii) Do I need to coat the brick work and good plaster patches (if they can stay) with a pva mix.
In the pictures you will see that where there is good plaster at the top half of the wall the finishing plaster has been removed as it come off when I took the top half of tiles off (the other tiles below and around the rest of the bathroom where fitted when the house was built and were really set in to the wall hence more of the under plaster came off with the tiles.
pics here - //www.diynot.com/network/macgrl/albums/
I should say and that the pics I have taken are upside down for some reason. So sorry for that... neither myself or the camera were upside down at the time of taking !
Many thanks
Read more: //www.diynot.com/forums/plaste...laster-over-old-plaster.312078/#ixzz1m04RSPl2
Hello all,
My questions are
Many thanks
