A chimney breast has been removed, leaving the timbers unstable.
As the joists sat on the brickork, now that chimney is removed they are flush to the wall.
A stairwell has been cut out and a trimmer joist put in but the job is a bit shady!!
The trimmer has been butted upto the existing joists and been bolted thru with coach bolts(2 in each joist end)
NO other means of support has been added, so the timber has dropped 3/8'' to 1/2'' on one end of the timber.
The whole weight of the upper floor etc is supported on these bolts!!
The original joists that were supported on the chimney breast have been doubled up and made good in the wall, giving abit of support, but if you look at my photos they've also got angle iron supporting a few of the existing joists that fell short.
Anyway i,ve took plenty of photos which can be viewed in MY ALBUM in my profile.
Heres one to give you a idea?
[/img]
[/img]
