Hi DIY folks,
I have just purchased an electric water conditioner. I need a power supply point (3 amp) to connect the device to.
I have located the cold water mains supply (in the bathroom), and the nearest electrical point is in the airing cupboard.
In the airing cupboard, there is a non-fused spur. Now, since I've moved in, this has Always been switched off.
My problem is, that I would like to use this fused spur point, and replace with a standard 3-pin plug socket. I haven't as yet taken the FCU cover off, and will of course shutdown the whole CU to be on the safe side.
I've looked at the CU to try and locate the relevant fuse, but it's hard to identify what the fused spur powered, IF it powered anything.
Any advice? Is it possible to use the point?
Cheers
S
Cheers
S
