Re-using cooker cable
20 Nov 2005
I've decommissioned cooker socket as old kitchen is being converted to bedroom. However, I need a new 30 Amp double power socket not far from the old cooker point.
I see that the cooker cable wires are much thicker than the standard power circuit cable - can I re-use the cooker cable to power a standard socket? If so, this would save lots of time hunting for the 30 Amp power cable to spur into.
Mike.
You can reuse it, but ideally you will change the fuse at the board if the circuit is fused above the 30 amp requirement for a socket circuit.
